Hi! I'm running a simulation on solidworks. It’s a simple simulation though the model is a complex geometry. I'm having problems obtaining the mesh, not because of the parameters but because it says that at least two bodies are interfering. I run the interference analyses with all option selected and there are only coincidente type of interference and it’s suposed to be cause the bodies are connected. I made the assembly from the beggining in new folders a thousand times to make sure that it wasn’t na ocasional error. Do you have any solution? I don’t know what to do.
Hi Flávia,
Can you attach this model to your post. That would let us go through the model and help locate what is causing the interference warning.
