Attached is a single assembly driven part. Edit plane 1 or 2 in the assembly, the sheet metal part will update.
Except the cross break will not update. Any idea's on how to edit the cross break sketch in a way it will update when the assembly planes move?
Scott Leacox - One thing I did was edit the Cross Break2 Sketch and apply the sketch relations to the center of the bend area
Then there is a circular rebuild issue going on here - To have it rebuild properly you need to edit the Cross Break2 sketch and then close, then rebuilds ok...
