I want to produce a render of a Pepper ghost exhibit
Is there a way to achieve a 2 way mirror (half silvered mirror) appearance in Visualize? i.e. if there is more light behind the mirror you will see through. If there is more light in front of the mirror than behind, it will reflect - like a police line up / interrogation room
Hi Allan
If it is for a rendering and not an animation, I would create two apperances; a mirror and a window to simplify the issue.
You can even set it up as two different configurations. Then you can easily switch between the two different looks.
You could perhaps make a decal to put on one side of the glass, and give it a mirror appearance. Maybe you could get your desired effect by playing around with that. Not sure if that can work though...
