Hello.
I have the multibody part and want to get the number of folders(thanks to Keith), I got it, and then I try to check each folder on including/excluding in the cut list.
I modified Keith's code:
Dim swFeat As SldWorks.Feature
Dim Foldercount As Integer
Dim EXCL as integer
Set swModel = swApp.ActiveDoc
Set swFeat = swModel.FirstFeature
Foldercount = 0 'number of all folders
EXCL = 0 'number of excluded folders
While Not swFeat Is Nothing
If swFeat.GetTypeName = "CutListFolder" Then
Debug.Print swFeat.Name
If swFeat.ExcludeFromCutList = True Then 'here I want to check the folder
EXCL = EXCL + 1 'count of folders excluded from the cut list
Debug.Print EXCL
Foldercount = Foldercount + 1
Set swFeat = swFeat.GetNextFeature
Wend
swApp.SendMsgToUser intCount & " folders in the solid bodies folder."
Thank you.
Hello
Dim EXCL As Integer
If swFeat.ExcludeFromCutList Then
EXCL = EXCL + 1
Debug.Print EXCL
Wend
swApp.SendMsgToUser EXCL & " folders excluded from the cut list out of " & Foldercount & " folders."
