Export all opened sheetmetal parts to DWG and add DWG Textbox
Question asked by Damir Galic on Jun 29, 2018
Latest reply on Jul 2, 2018 by X. Men
Option Explicit
Dim boolstatus As Long
Dim errors As Long
    Dim FileSavedCount As Long
    Dim FailedToSaveCount As Long
    Set swModel = swApp.GetFirstDocument
    While Not swModel Is Nothing
        If swModel.GetType = swDocPART Then
            If Not swModel.GetBendState = 0 Then 'if part is sheet metal
                Set swPart = swApp.ActivateDoc2(swModel.GetTitle, True, errors)
                Dim targetFilePath As String
                Dim modelPath As String
                modelPath = swModel.GetPathName
                targetFilePath = Left(modelPath, InStr(modelPath, ".") - 1) & ".DWG"
                boolstatus = swPart.ExportToDWG2(targetFilePath, modelPath, swExportToDWG_ExportSheetMetal, True, 0, False, False, 2053, Null)
                If boolstatus Then
                    FileSavedCount = FileSavedCount + 1
                Else
                    FailedToSaveCount = FailedToSaveCount + 1
            Else
                MsgBox (swModel.GetTitle & "Part is not sheet metal")
        Else
            MsgBox (swModel.GetTitle & "Document is not a Part.")
        Set swModel = swModel.GetNext
    Wend
    MsgBox (FileSavedCount & " dwg file(s) exported, " & FailedToSaveCount & " file(s) failed")
How do i add to above program that would also hide hidden lines, bend lines, bounding-box, all text and add a text block above drawing with this definition:
Name: "some property in configuration"
Thickness: thickness
Material: "some property name in configuration"
Would like to see where to change option for bounding box to display, in case the part is not fully flattened.
