Dear all,
I've a small macro that works perfectly (the macro change the size of a sketch text). I try to put this macro in a macro feature, but the selection of the sketch doesn't work any more when it's inside a Function.
To be honest, I just copy past part of code I found. I'm really bad une VBA. If you have any clue for me, I take it. I'm pretty sure that the problem is somewhere at the "SelectByID2" and at the "Rebuilt", because If I manually select the Text Sketch, it works.
Thanks already !
The Working Code :
Dim App As SldWorks.SldWorks Dim Doc As SldWorks.ModelDoc2 Dim SelMgr As SelectionMgr Dim text As SketchText Dim format As TextFormat Sub main() Set A = Application.SldWorks Set Doc = App.ActiveDoc Set SelMgr = Doc.SelectionManager Doc.Extension.SelectByID2 "Sketch7", "SKETCH", 0, 0, 0, False, 0, Nothing, 0 Doc.EditSketch Doc.Extension.SelectByID2 "SketchText1", "SKETCHTEXT", 0, 0, 0, False, 0, Nothing, 0 Set text = SelMgr.GetSelectedObject6(1, -1) Set format = text.GetTextFormat format.CharHeight = Doc.Parameter("D1@Fillet3").SystemValue / 1.5 text.SetTextFormat False, format Doc.EditRebuild3 End Sub
The not Working Code :
Dim App As SldWorks.SldWorks Dim Doc As SldWorks.ModelDoc2 Dim FeatureMgr As SldWorks.FeatureManager Dim Methods(8) As String Dim Names As Variant Dim Types As Variant Dim Values As Variant Dim ThisFile As String Dim Options As Long Dim MacroFeature As Feature Function swmRebuild(vrApp As Variant, vrPart As Variant, vrFeature As Variant) As Variant Dim SelMgr As SelectionMgr Dim text As SketchText Dim format As TextFormat 'Set App = Application.SldWorks 'Set Doc = App.ActiveDoc Set SelMgr = Doc.SelectionManager Doc.Extension.SelectByID2 "Sketch7", "SKETCH", 0, 0, 0, False, 0, Nothing, 0 Doc.EditSketch Doc.Extension.SelectByID2 "SketchText1", "SKETCHTEXT", 0, 0, 0, False, 0, Nothing, 0 Set text = SelMgr.GetSelectedObject6(1, -1) Set format = text.GetTextFormat format.CharHeight = Doc.Parameter("D1@Fillet3").SystemValue / 1.5 text.SetTextFormat False, format Doc.EditRebuild3 End Function Sub main() Set App = Application.SldWorks Set Doc = App.ActiveDoc If Doc Is Nothing Then App.SendMsgToUser2 "Il n'y a pas de document actif. P'tit con !", swMbWarning, swMbOk Exit Sub End If ThisFile = App.GetCurrentMacroPathName Methods(0) = ThisFile: Methods(1) = "Main_Programme": Methods(2) = "swmRebuild" Methods(3) = ThisFile: Methods(4) = "Main_Programme": Methods(5) = "swmEditDefinition" Methods(6) = "": Methods(7) = "": Methods(8) = "" 'A security routine is optional Names = Empty Types = Empty Values = Empty Options = swMacroFeatureByDefault Set FeatureMgr = Doc.FeatureManager Set MacroFeature = FeatureMgr.InsertMacroFeature("Text size", "", (Methods), Names, Types, Values, Nothing, Options) End Sub Function swmEditDefinition(varApp As Variant, varDoc As Variant, varFeat As Variant) As Variant End Function
I solve a part of my problem, I replaced :
By :
Now all the transformations of the sketch text work. My next problem is to exit the sketch.
