Is it possible to open a main assembly drawing and then run a macro that saves it as a PDF, but also finds all of the sub-assembly and component drawings and saves those as PDFs as well? I've been looking up posts, googling, and trying out code all afternoon but have had no luck.
The closest I got was last week when I started trying to write this macro. I made a dynamic array of the file names contained in the assembly and a loop that went through the array and saved a PDF under each name, but the differently-named PDF files themselves were all of the main assembly since that was the open document. I've tried finding a way to access these sub-assembly/parts to save as PDFs but have had no luck. Optimally they wouldn't be opened in a window in SolidWorks (just in memory) so as to improve performance and not clutter up the user's SolidWorks window every time the macro is run.
Thank you to all of the guys who have helped me with macros so far - your help has been appreciated!
Hello, Try this with an opened assembly file.
Dim swConf As SldWorks.Configuration
Dim swRootComp As SldWorks.Component2
Set swAssy = swApp.ActiveDoc
Set swConf = swAssy.GetActiveConfiguration
Set swRootComp = swConf.GetRootComponent3(True)
TraverseComponent swRootComp
PrintDrawing swAssy.GetPathName
Sub TraverseComponent(swComp As SldWorks.Component2)
Dim vChilds As Variant, vChild As Variant
Dim swChildComp As SldWorks.Component2
Dim MyString As String
vChilds = swComp.GetChildren
For Each vChild In vChilds
Set swChildComp = vChild
Dim FilePath As String
FilePath = swChildComp.GetPathName
TraverseComponent swChildComp
PrintDrawing FilePath
Next
Sub PrintDrawing(FileName As String)
FileName = Left(FileName, InStr(FileName, ".") - 1)
If Dir(FileName & ".SLDDRW") = "" Then Exit Sub
Dim swDraw As SldWorks.ModelDoc2
Set swDraw = swApp.OpenDoc6(FileName & ".SLDDRW", 3, 0, "", longstatus, longwarnings)
Dim swExportPDFData As SldWorks.ExportPdfData
Set swExportPDFData = swApp.GetExportFileData(1)
If swExportPDFData Is Nothing Then
MsgBox "Nothing"
Exit Sub
swExportPDFData.ViewPdfAfterSaving = False
boolstatus = swDraw.Extension.SaveAs(FileName & ".PDF", 0, 0, swExportPDFData, longstatus, longwarnings)
swApp.CloseDoc swDraw.GetTitle
