Hi, I noticed a problem when working with sheet metal and then converting it to visualize project.
if you notice the cone of the vessel is not cone, but multiedged cone. I used sheet metal to make it and loft from higher diameter to upper lower diameter.
If I increase detail in solidworks, it creates more of edges, however solidworks starts working pretty slow - but nowhere nearly as slow as visualize where it practically can't handle the object.
I assume revolving without using sheet metal loft would make a better shape? The problem is that all my vessels are made this way...
This can be done on the part level. Here's an example.
/M
