Export all opened Sheetmetal parts to DWG
Question asked by X. Men on Jun 26, 2018
Latest reply on Jun 29, 2018 by Damir Galic
I've made a script from the code collected from different sources. It exports a flatten dwg file if there is only one opened file, but when there are 2 files, nothing get exported.
Here is the code
Private Declare PtrSafe Sub Sleep Lib "kernel32" (ByVal dwMilliseconds As Long)
    Dim FileSavedCount As Long
    Dim FailedToSaveCount As Long
    Dim options As Long
    Dim fso As New FileSystemObject
    options = 2053
    Set swModel = swApp.GetFirstDocument
    While Not swModel Is Nothing
    'If swModel.Visible = 1 Then
        If swModel.GetType = swDocPART Then
            If Not swModel.GetBendState = 0 Then 'if part is sheet metal
                 Dim targetFilePath As String
                 Dim modelPath As String
                 modelPath = swModel.GetPathName
                 targetFilePath = fso.BuildPath(fso.GetParentFolderName(modelPath), fso.GetBaseName(modelPath) + ".DWG")
                 swModel.ExportToDWG2 targetFilePath, modelPath, swExportToDWG_ExportSheetMetal, True, 0, False, False, options, Nothing
                 ' Sleep 5000 ' Tried to sleep but doesn't solve the problem
                 If fso.FileExists(targetFilePath) = False Then
                     FailedToSaveCount = FailedToSaveCount + 1
                 Else
                     FileSavedCount = FileSavedCount + 1
            Else
                MsgBox (swModel.GetTitle + "Part is not sheet metal")
        Else
            MsgBox (swModel.GetTitle + "Document is not a Part.")
    'End If
    Set swModel = swModel.GetNext
    Wend
    MsgBox (CStr(FileSavedCount) + " dwg file(s) exported, " + CStr(FailedToSaveCount) + " file(s) failed")
