Hi there
Does somebody have the same issue with bloom effect in VR? Where the environment is stitched together, there is a different amount of bloom and a strong visible transition. Without bloom everything is perfect.
Here I have the same frame with and without bloom.
Hi Kevin,
You're not alone experiencing this "seam" issue with Bloom filter. If my memory serves me correct, this is a current limitation of Iray. We've asked them to fix it, but I'm not sure a solution can be found here. We have a call with Iray team tomorrow and I will bring this up again to see how it can be solved.
Brian
