Hi Guys,
I was doing an internal flow analysis when I encountered the "Mass flow is out of fan curve's range" warning message. My analysis involved an electronic enclosure with several electronic components and 3 internal fans. The warning is showing on 1 of the fan.
I was not able to add more fan curve point as I have added what is stated in the fan specification. I still can proceed with the simulation but the temperature fluctuates rather than stabilizing to a constant value. I want to know whether I can still trust the value or should I treat the internal fan as external fan when the cover of the enclosure is taken off.
Hope to hear from you soon.
I've had simular problems with the fan tool. In the end I found a working point close enough to the fan curve and satisfied there, even though the warning was still there.
Following your thread to see if any solution appears.
