13 Replies Latest reply on Jun 29, 2018 11:59 AM by Alex Caicedo
    Dir not working on drawings I never opened
    Alex Caicedo
      Hey guys,
      I have written a macro to batch print PDFs (using the one passed around here with some updates);however, there is one problem I keep having. Anytime the macro tries to open a part from PDM that I have never opened/viewed in SolidWorks before, the Dir function returns a False value and the variable is blank. I actually cut down the code to just the line that contained the Dir function so I could test out a theory:
      Dim swApp As Object
      Dim Filename As String
      Filename = Dir("C:\PAS-EPDM\A Systems\ 2018\plastics\CAD\" & "360446" & "*.slddrw")
      MsgBox Filename
      'Set swApp = Application.SldWorks
      When I run this (knowing that that part is absolutely in that file path), the message box comes out blank. But then, when I open that part in SolidWorks from that location, close the part, then re-run the exact same macro, the message box returns "360446.slddrw" and I can open it with additional code. I tested this on several parts I've never opened before (even running the macro a couple times before opening the part) and the same thing happens.
      Is there any way to get the Dir function to recognize files that are in the file path that I never opened or am I stuck only using this on Dwgs that I have opened previously?
      Any help would be greatly appreciated!
        • Re: Dir not working on drawings I never opened
          Artem Taturevych
          This file is not cached in PDM local folder so it doesn't exist on your drive - that's why it is failing. You need to create local copies. Either use IEdmFile5::GetFileCopy or IEdmBatchGet from PDM API or just get the local cache from user interface in your vault.
            Jason Kerns
            Dim vault As EdmVault5
            Dim Nfile As IEdmFile5
            Dim Vfolder As IEdmFolder5
            Set vault = New EdmVault5
            'CHANGE THIS TO YOUR VAULT NAME
            If Not vault.IsLoggedIn Then
            vault.LoginAuto "PDM VAULT NAME GOES HERE", 0
            Set Nfile = vault.GetFileFromPath("FilePath", vfolder)
            Nfile.GetFileCopy 0, 0
            'do stuff
            end sub
                Alex Caicedo
                Thanks Jason,
                I updated the code and it seems to run fine, but not sure what to do after that... I'm not experienced with EDM or GetFileFromPath functions. Do I just substitute "Nfile" from your code for "Filename" in my original code? For example, to open the part file I was using:
                Set swObj = swApp.OpenDoc6(Filename, Ftype, swOpenDocOptions_Silent, "", nErrors, nWarnings)
                I replaced "Filename" with "Nfile" but getting a type mismatch.... do you know how I can open the model after the line Nfile.GetFileCopy?
                thanks,
                    Jason Kerns
                    Hi Alex,
                    If you can send me, or post your code I can update it.
                    "Filename" does not need to be replaced with "Nfile".
                    "Filename" should be assigned before the "Set Nfile ..." line then you have a cached file from PDM.
                        Alex Caicedo
                        Hey Jason,
                        See below. The bold items are what I just added from your first post... just not sure where/how to use the Nfile.
                        Sub BatchPDFconvert()
                            Load PNlist_userform
                            PNlist_userform.Show
                            HelpMsg = ""
                            PNarray = Split(PNlist_userform.PNinput, vbCrLf)
                            PNlength = UBound(PNarray)
                            sPath = SelectFolder("Select Folder Where Drawings Are Located", "")
                            If sPath = "" Then
                                End
                            sPath = sPath + "\"
                            dPath = SelectFolder("Select Folder to Store PDFs", "")
                            If dPath = "" Then
                                End
                             dPath = dPath + "\"
                            vault.LoginAuto "PAS-EPDM", 0
                            For i = 0 To PNlength
                                sFilename = Dir(sPath & PNarray(i) & ".slddrw")  ''NOT OPENING FILES THAT HAVE NEVER BEEN VIEWED
                             Set Nfile = vault.GetFileFromPath(sFilename)
                                If sFilename = "" Then
                                    HelpMsg = HelpMsg & PNarray(i) & vbNewLine
                                    GoTo NextIncr
                                Set swDraw = swApp.OpenDoc6(sPath + sFilename, swDocDRAWING, swOpenDocOptions_Silent, "", nErrors, nWarnings)
                                Set swDraw = swApp.ActiveDoc
                                dFileName = Mid(swDraw.GetPathName, 1 + InStrRev(swDraw.GetPathName, "\"))
                                dFileName = Left(dFileName, InStrRev(dFileName, ".") - 1)
                                swDraw.SaveAs3 dPath & dFileName & ".PDF", 0, 0
                                swApp.QuitDoc swDraw.GetPathName
                                Set swDraw = Nothing
                        NextIncr:
                            Next i
                        If HelpMsg <> "" Then
                                MsgBox "Drawings that were not found in file path " & vbNewLine & sPath & vbNewLine _
                                    & HelpMsg & "Re-run macro with new location for drawings above.", , "Error Report"
                            Jason Kerns
                            I see this is missing. replace your line with mine.
                            Set Nfile = vault.GetFileFromPath(sFilename, Vfolder)
                                Alex Caicedo
                                I am still getting an error on the Nfile.GetFileCopy line: "Object variable or With block variable not set."
                                I condensed the code so I can just work on this section.. any ideas?
                                Dim swApp As Object
                                Dim sFilename As String
                                Dim sPath As String
                                sPath = "C:\PAS-EPDM\Aquatic Systems\ 2018\CLEANERS\CAD\"
                                sFilename = Dir(sPath & "360400" & ".slddrw")
                                'MsgBox sFilename
                                Nfile.GetFileCopy 0, 0 'ERROR
                                Set swObj = swApp.ActiveDoc
                                'do stuff
                                    Artem Taturevych
                                    Change
                                    to
                                    sFilename = sPath & "360400" & ".slddrw"
                                        Alex Caicedo
                                        So I think that fixed the error on the Nfile.GetFileCopy, but I am now getting an error on the line that is supposed to open the drawing... its a type mismatch error.
                                        Is there a better way to open the drawing?
                                        thanks,
                                            Artem Taturevych
                                            Should be
                                            Set swDraw = swApp.OpenDoc6(sFilename, swDocDRAWING, swOpenDocOptions_Silent, "", nErrors, nWarnings)
                                                Alex Caicedo
                                                I am still getting a Type mismatch error on the Set swDraw line. Just to make sure I don't have anything else incorrect, here is what I am running.
                                                Dim swApp As Object
                                                Dim sPath As String
                                                Dim swDraw     As Object
                                                sFilename = sPath & "371998" & ".slddrw"
                                                'MsgBox sFilename
                                                'do stuff
                                                    Jason Kerns
                                                    Dim swApp As Object
                                                    Dim sPath As String
                                                    Dim swDraw     As SldWorks.ModelDoc2
                                                    Dim nErrors As Long
                                                    Dim nWarnings As Long
                                                    Debug.Print sFilename
                                                    'do stuff
