0 Replies Latest reply on Jun 22, 2018 8:09 AM by Brian Brazeau
    Are there any downloadable GoAutomate examples?
    Brian Brazeau
      Hi All, I recently downloaded GoAutomate and have been messing around with it a little. I've done dimensions, features(suppress/unsuppress), and equation to some extent, but the help is not the best and I am struggling with some of the other functions. Are there any example files out there that could be interrogated to learn from?
      Attached is what I was messing around with. The pink fields are fields the user would input. The one at the top is a drop down list where you just pick. The others are plate thicknesses and such. I noticed if you make a larger mold base everything works fine. If you make a smaller mold base SW shows errors, but if you switch to the SW window and do Ctrl+Q they go away.
