Can we change the contour selection/sketch visibility behaviour?
Question asked by Francis Fowler on Jun 21, 2018
Hi all,
So I just wasted another hour trying to work out why I couldn't select certain sketch contours for an extrude.  Searching through the forums I found someone else with this problem, and it was caused by sketch visibility being turned off.  As soon as I read this, I knew this was the problem I was having - I've been there a number of times before.  The thing is when trying to select contours, it is completely unobvious that sketch visibility has to be turned on as I can ACTUALLY SEE the sketch.  What does turning off sketch visibility even do?  I just can't understand the logic supposedly involved here.
OK sorry, that was a bit of a rant, but is anyone able to explain how sketch visibility works?
Francis
