Hi everyone. I have been using draftisght for about a year now and recently started having a problem with editing text boxes. When I double click on a textbox to edit the text draftisight auto zooms in on the textbox. Then when I click outside the textbox it auto zooms back out. It only happens on some text boxes and not all of them. Does anyone know how to turn this annoying feature off in draftisght? Thanks.
Hi Jeremy, I updated to 2018 SP3 and inherited this PITA 'feature' as well! I called Draftsight support and they had no clue. After messing around a bit I found the fix. Just double click the text box and open the contextual menu, goto 'Editor Settings' and check 'Always show WSIWYG'. Also, I found that your drawing zoom level determines when the problem appears if you leave it unchecked.
Does this fix it?
Keith
