1) I need to make an option in the property tab builder that has 4 different options, each with a different long text box appearing in the drawing sheet title box. I can't figure out how to make that appear correctly.
2) Does the custom properties tab follow the drawing or the user? I need this tab to be with these .drwdot drawing templates, but it doesn't appear on other computers.
Hi Valerie,
How do you want the text to behave? Should it only show one of the 4 options?
If only one is to be shown, you could use a radio button, that will switch the text to only which ever option is selected. add a fifth radio if you want to make it blank.
If you want to turn any combination of them on, you could use checkboxes.
The custom property tab should attach to the template. But you will need to store the templates on a network drive then point everyones settings to the same location through System Options>File Locations
