Combine 2 macros--> delete propertys and equations
Question asked by Franz Dahinden on Jun 21, 2018
Latest reply on Jun 21, 2018 by Franz Dahinden
I have this 2 macros and would like to combine them;
1.delete propertys
2. delete equations
I do not have enThanks a lot
I do not have enough experience to do this, At the moment I make 2 klicks on my macros.
Option Explicit
Dim swModel As ModelDoc2
Dim cpm As CustomPropertyManager
Sub DeleteProps()
Set swModel = swApp.ActiveDoc
Dim names() As String
Set cpm = swModel.Extension.CustomPropertyManager("")
names = cpm.GetNames
Dim i As Integer
For i = 0 To UBound(names)
cpm.Delete names(i)
Next
_______________________________________________________________________________________________________________________________________________________________________________________________________________________________________________
Const DELETE_BROKEN_ONLY As Boolean = False 'if this flag is True than only broken equations are deleted, otherwise all equations are deleted
Dim swEqMgr As SldWorks.EquationMgr
    Dim hasDeleted As Boolean
    DeleteEquationsFromModel swModel, hasDeleted
    If swModel.GetType = swDocumentTypes_e.swDocASSEMBLY Then
        If MsgBox("Do you want to delete equations in all components of the assembly?", vbYesNo) = vbYes Then
            Set swAssy = swModel
            'component needs to be loaded in memory in order to process it's equations
swAssy.ResolveAllLightWeightComponents True
            Dim vComps As Variant
            vComps = swAssy.GetComponents(False)
            Dim i As Integer
            For i = 0 To UBound(vComps)
                Set swComp = vComps(i)
                Dim swCompModel As SldWorks.ModelDoc2
                Set swCompModel = swComp.GetModelDoc2
                If Not swCompModel Is Nothing Then
                    Dim hasCompEqDeleted As Boolean
                    DeleteEquationsFromModel swCompModel, hasCompEqDeleted
                    If hasCompEqDeleted Then
                        hasDeleted = True
            Next
    If hasDeleted Then
        swModel.ForceRebuild3 False
Sub DeleteEquationsFromModel(model As SldWorks.ModelDoc2, ByRef hasDeleted As Boolean)
    Set swEqMgr = model.GetEquationMgr()
    Dim i As Integer
    hasDeleted = False
    'iterate in the reverse direction as the equation index will change once previous equation is deleted
    For i = swEqMgr.GetCount - 1 To 0 Step -1
        If Not DELETE_BROKEN_ONLY Or IsEquationBroken(swEqMgr, i) Then
            swEqMgr.Delete i
            hasDeleted = True
    Next
    If hasDeleted Then
        'deleting equation doesn't make the model dirty
        model.SetSaveFlag
Function IsEquationBroken(eqMgr As SldWorks.EquationMgr, index As Integer) As Boolean
    Const STATUS_BROKEN As Integer = -1
    Dim val As String
    val = eqMgr.Value(index) 'evaluate to get the status
    IsEquationBroken = (eqMgr.Status = STATUS_BROKEN)
End Function
