14 Replies Latest reply on Jun 19, 2018 11:19 AM by Aleksandras Korolkovas
    Get5 (CustomPropertyManager) returns value, which by description is not possible
      For me this issue is very hard to solve and is nessesary to solve.
      In my code I have such line:
      STatusInt = custPropMgr.Get5("Aiva", False, Value, resolvedValue, isResolvedValue)
      and if I understood get5 function description right
      2017 SOLIDWORKS API Help - Get5 Method (ICustomPropertyManager)
      then isResolvedValue cant be false.
      Possibly function took longer to spit out value, but isResolvedValue value must be true.
      On my PC where is visual studio installed it is always true, but on all other computers usually it always false.
      I have checked this on my pc in debug mode and as solidworks addin command (logging to txt file). On other  computers only with logging to file.
      Someone can tell me what can be wrong?
        • Re: Get5 (CustomPropertyManager) returns value, which by description is not possible
          Jim Sculley
          Create a small, complete example that exhibits the problem.  Then post it here.
            Alex Burnett
            It is difficult to tell what exactly is going on from the description you have given. I'll try to explain what the purpose of the isResolvedValue.
            Suppose you have the following custom property table:
            If you use Get5 then the following should apply for Material.
            isResolvedValue is true          result: Alloy Steel
            isResolvedValue is false          result: SW-Material@76320.sldprt
            I hope that makes sense. Good luck!
              a bit more explanation
              this is how api help describes function
              Dim instance As ICustomPropertyManager
              Dim FieldName As System.String
              Dim UseCached As System.Boolean
              Dim ValOut As System.String
              Dim ResolvedValOut As System.String
              Dim WasResolved As System.Boolean
              Dim value As System.Integer
              value = instance.Get5(FieldName, UseCached, ValOut, ResolvedValOut, WasResolved)
              this is how function return values acording to UseCashed
              If UseCached is set to...
              And the configuration has already been activated...
              Then...
              True
              Yes
              Up-to-date data is returned and WasResolved = true
              True
              No
              Cached data is returned and WasResolved = false
              False
              Yes
              False
              No
              So, as I understood, if put false, then it will always resolve value and WasResolved returns True.
              But...
              code lines:
              AddInLoger(String.Format("StatusInt ={0}; isResolved = {1}; Parameter value: {2}", STatusInt.ToString, isResolvedValue.ToString, resolvedValue.ToString)) 'it is special function to write txt log file and see where error is on other pc
              on my pc second line wrtes to txt:
              >>> StatusInt =2 ; isResolved = True; Parameter value:  Stainless pipe 42.4x2 polished AISI 316
              on any other pc where this ADDIN command is used:
              >>> StatusInt =2; isResolved = False; Parameter value:
              Solidworks by itself showing resolved values on all computers, just api calls returns diferent values.
              tested on the same solidworks assembly and the same part. With Get5 I geting values from weldmember bodies in cut list.
              Jim, is no sense to put here example if only one code line act diferently on other pc and I want know why.
              Alex, I knew this, but it is from another opera.
                  Artem Taturevych
                  Alex, isResolved is ByRef parameter, not ByVal (so it is returned from the function, not expected by the function as an input). The expression and the resolved value is returned in the valOut and resValOut parameters respectively.
                  I think what isResolved tells you is if you can truly 'trust' the value returned. Let me explain what I mean.
                  For some performance improvements SOLIDWORKS is not caching the values within the configurations. So when property is accessed there is an option to specify if you want that to return from cache (i.e. instant) or that should resolve the configuration. You can do a test and purge the cache from the configuration so you can see minus instead of green check against the configuration name. Now when you specify False as cached parameter of Get5 you will see that SW will activate all configurations while getting the property so it would take some time. Otherwise it will return an instant value from the cache. I assume there may be the case when cached value won't be equal to the actual value (not updated) so the returned property is invalid.
                  Aleksandras, I have tried to do some tests to prove my theory above, but for me the isResolved is inconsistent even within my machine. I have tried different options (e.g. changing the property within the document manager, pdm, purging the data, linking to dimension etc) but that always returned the valid resolved value while isResolved keep changing both when I use cached and not cached option. So seems like a bug to me (or maybe invalid documentation). I would recommend to use the 'cached = false' and ignore the isResolved option as you will get up-to-date value anyway. Or you might contact API Support for clarification.
                  Artem
                      Artem, thanks for answer.
                      In any case i use 'cached = false', but not only "isResolved' returns 'False'. In my biger explanation you can see 'resolvedValue' can return empty string when in Solidworks I see value which is resolved and not empty. This log making function shows that on other PC isResolved always false but 'resolvedValue' not always empty. Anyway, i cant trust this value, because later it goes to ERP program.
                      On other PC's with ADDIN dll file in same directory placed other library dll files. This files is required to make ADDIN work. I dont see diference in version of dll libraries on my PC and other PC's, but probably they can be... Can it be that they are cause of this issue?
                        Alex Burnett
                        Artem, you are correct. I was going a bit by memory and it turns out the SolidDNA API that I am using wrapped the Get5 method with a more intuitive function. That function takes an input of whether you want the resolved value or not.
                        The function that calls Get5 actually has UseCached set to false for all calls. So in agreement with your answer, I would set UseCached to false so that you force SolidWorks to evaluate the data so it will always be up to date. If you're forcing it to evaluate every time, the wasResolved output should theoretically always be true.
                        The only scenario I can see the wasResolved value being needed is if UseCached is set to true and there may or may not already be a value in the cache. This way you could see if it is evaluated when called rather than pulled from the cache.
                      Ivana Kolin
                      are you getting properties from your active doc (main assembly or part) or from one of the components. Is it by chance possible that user has components in lightweight mode?
                          I always resolving whole assembly before the all other code. From lightweigt components most values is not trustable or posible error "object cant be set to instance". It means, lightweigt component have chances be kind of invisiblity to API calls.
                          I resolve it with api call in beginning of code. So user doesn't have chances to miss resolve of all components.
                              Ivana Kolin
                              this is why Jim asked for complete example. Now we can only guess what you do.
                                  You think there is sence to show sample of thousand lines?  Less is no sence for me, because it will not show more than this single line. Main question why one line of code gives diferent values on diferent computers but with same assembly model.
                                      Alex Burnett
                                      We don't need to see your full code or anything. Like Jim said above, if you could create a small example part along with a short API that is calls the Get5 method and exhibits the issue you're describing then that would help immensely. From there, we may be able to debug or track down a scenario that causes your issue.
                                             Before this is checked that this part is single body and this body is weldmember (pipe, bar,.. any profile).
                                          Part is component of assembly.
                                          Part usualy have only one configuration.
                                          Assembly is fully resolved.
                                          Function getSingleBodyWeldmentparameterValues(ByRef SingleBodyWeldmentModel As ModelDoc2, ByVal RefConfigName As String) As Tuple(Of String, String)
                                                  Dim AiVaKodas As String
                                                  Dim AivaApr As String
                                                  Dim swSubFeat As Feature
                                                  Dim swFeat As Feature
                                                  Dim cutFolder As BodyFolder
                                                  Dim custPropMgr As CustomPropertyManager
                                                  Dim CutListBody As Body2
                                                  Dim CutListBodies As Object
                                                  Dim propNames As Object
                                                  Dim vName As Object
                                                  Dim propName As String
                                                  Dim Value As String
                                                  Dim resolvedValue As String
                                                  Dim ITM_N As Integer
                                                  Dim isResolvedValue As Boolean
                                                  Dim STatusInt As Integer
                                                  SingleBodyWeldmentModel.ShowConfiguration2(RefConfigName)
                                                  Dim modelName As String = Path.GetFileNameWithoutExtension(SingleBodyWeldmentModel.GetPathName)
                                                  swFeat = CType(SingleBodyWeldmentModel.FirstFeature, Feature)
                                                  ITM_N = 0
                                                  Do While Not swFeat Is Nothing
                                                      swSubFeat = CType(swFeat.GetFirstSubFeature, Feature)
                                                      Do While Not swSubFeat Is Nothing
                                                          cutFolder = Nothing
                                                          If swSubFeat.GetTypeName = "CutListFolder" Then
                                                              If swSubFeat.ExcludeFromCutList = False Then
        cutFolder = CType(swSubFeat.GetSpecificFeature2, BodyFolder)
                                                          If Not cutFolder Is Nothing Then
                                                              If cutFolder.GetBodyCount > 0 Then
        CutListBodies = cutFolder.GetBodies
        CutListBody = CType(CutListBodies(0), Body2)
        ITM_N = ITM_N + 1
        If CutListBody.IsSheetMetal = False Then
        custPropMgr = swSubFeat.CustomPropertyManager
        If Not custPropMgr Is Nothing Then
        propNames = custPropMgr.GetNames
        If Not IsNothing(propNames) Then
        For Each vName In CType(propNames, IEnumerable)
        propName = CStr(vName)
        If propName = "LENGTH" Then
        Try
        STatusInt = custPropMgr.Get5("Aiva", False, Value, resolvedValue, isResolvedValue)  '<-- This line gives diferent values depending on PC
                                          'line below write formatted string to text file
        AddInLoger(String.Format("StatusInt ={0}; isResolved = {1}; Parameter value: {2}", _
        If STatusInt <> 2 Or isResolvedValue = False Or resolvedValue = "" Then
        AivaApr = ""
        AddInLoger(String.Format("value is not trustable: {0}", AivaApr))
        Else
        AivaApr = resolvedValue
        AddInLoger(String.Format("Parameter value is ok: {0}", AivaApr))
        Catch ex As Exception
        AivaApr = ""
        AddInLoger(String.Format("exception {1} --------while try to get parameter value: {0}", AivaApr, ex.Message))
        End Try 'never got exception
                                          'another property
        Try
        STatusInt = custPropMgr.Get5("AivaKodas", False, Value, resolvedValue, isResolvedValue)
        AiVaKodas = ""
        AddInLoger(String.Format("value is not trustable: {0}", AiVaKodas))
        Else
        AiVaKodas = resolvedValue
        AddInLoger(String.Format("Parameter value is ok: {0}", AiVaKodas))
        AiVaKodas = ""
        AddInLoger(String.Format(" exception {1} --------while try to get parameter value: {0}", AiVaKodas, ex.Message))
        End Try
        Next vName
                                                          swSubFeat = CType(swSubFeat.GetNextSubFeature, Feature)
                                                      Loop
                                                      swFeat = CType(swFeat.GetNextFeature, Feature)
                                                  Loop
                                                  Dim RetTuple As New Tuple(Of String, String)(AivaApr, AiVaKodas)
                                                  AddInLoger(String.Format("Function returns: {0};  {1}", AivaApr, AiVaKodas))
                                                  Return RetTuple
                                              End Function
