hello, I am stuck with this specific model, despite repeated attempts I am unable to model the internal of the Sphere. A little background I am 3 month old user of solidworks and preparing for CSWA, during the course of my prep I downloaded a few practice model from internet, however I got stuck with this particular model with respect to modelling inside the sphere. It would be a great help if i could learn the ropes to do so
a side note; the dimensions in the solidpart are not as per drawing as during multiple tries i kinda let them loose to focus on the technique
See attached.
There are no sweeps involved. It is simple extrude boss, cut extrude, and revolve features. To make the sphereical cut with the two flats seen best from the cross section and top views a multi body modeling technique with a combine (Subtract Boolean) feature can be employed. Hope this helps.
There is one missing dimension - the height in cross section of the counterbore like feature. In my model it is the feature dimensioned 42mm from the base. Otherwise all of the dimensions are present.
