Hi, Occasionally, without any reason that I can understand, everything in an assembly can un-suppress as well as un-suppressing everything in all configured parts. I have just had this happen on a 1000+ part assembly which ends up being a total pain in the butt. This time it happened after I turned off a section view.
Anyone else have this issue or have any idea on what causes it? I would log an issue with solidworks but its so hard to replicate
Peter,
From what I can tell, and this has been seen across all of the machines where I work, if you "undo" a suppress feature you do, it will unsuppress all parts in any assembly that has configurations. We have learned to not undo a suppress, but I just did it today and was checking the forum to see if anyone had submitted a VAR to have it fixed. We have been seeing this behavior since switching to Solidworks 2018.
My suggestion, do not undo a suppress, but manually unsuppress any item you do not want suppressed.
