I am trying to add a hole table and looks like the table template does not exist, I tried adding a general table and looks like this one does not exist either.
Any idea what I can do?
try here.
found mine here I must be pointing to an old location
it looks like the path is correct but the files does not exist. What files do you see under the folder that you show?
I found all kinds of templates. you may want to check the SolidWorks data folder.
What version of SolidWorks are you using? (it's not listed in your profile)
The hole table templates have changed names since "standard hole table--letters.sldholtbt".
Did you recently upgrade SolidWorks and SolidWorks is looking for the old hole table template file name?
Cheers,
Kevin
try here.
