This content has been marked as final.
Show 4 replies
Re: Simulation addin available but i'm not able to select the new study
Ryan Dark Jun 15, 2018 11:40 AM (in response to KALIAPPAN KANAKESAN)Hi Kaliappan,
What version and service pack of SOLIDWORKS are you using. KB3072630 should not impact any recent version of SOLIDWORKS going all the way back to 2015 SP5.0. If you are on a newer version that than then something else is happening here.
KALIAPPAN KANAKESAN Jun 15, 2018 12:13 PM (in response to Ryan Dark)Hi Ryan,
We are using Solidworks 2013 sp4.0.
Ryan Dark Jun 15, 2018 12:23 PM (in response to KALIAPPAN KANAKESAN)Is this the fix process you went through to accommodate damage to add-ins done by KB3072630 (GoEngineer - SOLIDWORKS Installation - Fix for KB3072630)? If it is not I would recommend this be the next thing you try.
KALIAPPAN KANAKESAN Jun 18, 2018 8:34 AM (in response to Ryan Dark)Hi Ryan,
I had followed this solution Simulation authorization failed - 2010, w/ Simulation Premium lic. My issue was solved.
Thank for spending your valuable time with us.
-kaliappan
