Here's a feature that I have seen modeled a few different ways, and I'm curious what the experts here suggest is the best practice for modeling it.
I'm talking about a pressure transducer seat (image captured from Terwin Instruments website):
Ideally, it would be great to set this up as a hole wizard feature, because except for the 0.626 diameter counterbore depth which will vary depending on the wall thickness of the part, the other dimensions are more or less constant and generally speaking do not vary from hole to hole.
Thanks!
After much experimenting and head scratching I've found that if I modify that section of the hole without the baseline I get results similar to yours.
If I modify the hole with the use baseline dimensions box checked the elements under that one don't update.
However, if I modify the dimension without the Use Baseline Dimensions box checked then, after I modify the dimension and it looks all funky, and before closing the Advanced Hole dialog, check the Use Baseline dimensions box it seems to update correctly.
Hope this helps!
