Derek Fricke
Variable Diameter profile in swept cut, variable diamter helix ?
Discussion created by Derek Fricke on Jun 13, 2018
Latest reply on Jun 14, 2018 by Brian Brazeau
I am trying to reverse engineer a feed-screw.  The design has a variable pitch, variable diameter of helix, and variable profile.  The profile is where I am having the trouble.  The profile changes from 15mm to 14mm to 12mm at certain points.   I have looked at multiple ways of doing this and I keep running into hurdles.  What would be the best method ?
In addition, I have another feed screw that the swept profile intersects and I'm trying to do a swept cut which crashes.  What would be the most efficient process? Swept surface profile, then close off and convert to solid and do a subtraction?
Any pointers are greatly appreciated.
Regards,
Derek
