Hi there,
A simple question but still...
I have a Dell Precision Tower 5810 workstation with one Quadro M4000 GPU and I want to add one more Quadro P5000 or P4000 to speed up Visualize Pro workflow and rendering. As I understand Quadro and GeForce GPUs dont mix, right? So is there anything I should know about multiple different architecture Quadro GPUs in one system compatibility? Will I be able to fully utilize both GPUs when rendering? Does it matter which one is the "primary" one? Yada Yada...
Thanks for help.
I was told years back your system will run as fast as the lowest gpu. If this is still true your system will run like it has 2 M4000. Probably better off with just the P5000. But that might have changed
