I am encountering a problem with the copy settings wizard on both v2008 and v2009. When attempting to restore the settings to other users computers, all corporate settings (format locations, etc.) are copied into the registry except referenced documents search paths. I've opened the registry file (sldreg) and the locations are there, but will not load...
Currently our company does not utilize PDM and all released files are stored in a network drive that has an extensive amount of sub-directories. The amount of time it will take to have all the users map out these drives will be extensive and I will not be able to ensure consistancy.
Has anyone else experienced this problem, and if so, is there a soultion?
Personal Opinion... Solidworks needs to take a lesson from PTC and use a text based file (similar to search.pro) that can be easily modified, reside in a standards directory and accessed thru the options button.
There should also be a way for administrators to enforce standards locations and their usage (Set and then "grey-out" settings such as formats, templates etc.) such a PTC's config.sup
What kind of user is that for whom you are restoring the settings? Does have permission on those reg key?
