Re: Assembly internal parts, detail in drawings
Deepak Gupta Jun 13, 2018 2:58 AM (in response to Dan Popcioanca)Sorry you can create drawings for virtual or internally saved components directly. So you either need to save them externally Or create configuration/display state in assembly.
Kieran Young Jun 13, 2018 4:06 AM (in response to Dan Popcioanca)Hi Dan,
When you create a drawing view of an assembly you should get he option for 'components to exclude'. If you don't you can access this through the drawing view properties.
Providing there aren't hundreds of parts in the assembly this may work for you.
Kieran
Dan Popcioanca Jun 13, 2018 11:06 AM (in response to Kieran Young)Thank you. I will have to test this out as well. I actually saved the parts separate since there weren't many; but I'll take a look next time I run into this.
Deepak Gupta Jun 13, 2018 11:52 AM (in response to Kieran Young)Kieran Young wrote:
Hi Dan,
When you create a drawing view of an assembly you should get the option for 'components to exclude'. If you don't you can access this through the drawing view properties.
I believe that option you mean is hiding the components OR are you referring to section views options?
Dan Popcioanca Jun 13, 2018 11:57 AM (in response to Deepak Gupta)I mean detailing out individual components, parts, that live inside the assembly. The Drawing itself is of the assembly, but would like to pull parts out from there. (w/out having them saved externally, or separate configs )
Deepak Gupta Jun 13, 2018 12:08 PM (in response to Dan Popcioanca)As stated earlier this is current limitation since drawings need a model. So your best option is either configuration or display states.
In case you have to make only one drawing and only one time, then you can hide the other components in the drawing view.
Kieran Young Jun 14, 2018 3:31 AM (in response to Deepak Gupta)Oh you are right Deepak. The option I meant was hide/show components in the view properties.
