Ello all
I am currently working on my first drawing. I do not have any templates set up so I am using the default ANSI landscape for 17x11 paper size with default title block.
I have dimensioned my drawing, driven and driving, and have finished adding all my notations. Where I am having trouble, with my PART MODEL open, I go to file>properties>custom. From here I add stuff such as PROJECT for property type, text for type, then DRAWING DEMO for value or text expression. I hit ok/save and go back to my drawing and nothing has been updated in the title block area.
here is my part.. its a strange part to. no idea its function...
Could it be that I made it on one pc at school which uses 2017, then I went to another campus that uses 2018??
thanks@EVERYONE!!!!!!!
Your drawing doesn't have anything that links to model property. So you need to fix/update your drawing in order to display the required property value.
This should be help in getting started How to Create Drawing Templates and Sheet Formats in SOLIDWORKS
