I have this kind of code to automatically get solidworks drawing name when drawing is not saved and save drawing DXF and PDF.
If the drawing is not saved it will save the drawing with standard name but then the code will want to save the drawing again and this fails. How do I edit this that the secound part will be jumped over if that macro saves the drawing as brand new. And then to skip the first part If the drawing is already saved (this is not nessesary) The code still works if there is already saved solidworksdrawing It just saves the drawing two times and the PDF and DXF. Now I need to run this macro twice First time just to save the drawing. Then I get run-time error 5. Then when i run it again it saves DXF and PDF.
Dim swModelDocExt As SldWorks.ModelDocExtension
Dim swExportData As SldWorks.ExportPdfData
Dim boolstatus As Boolean
Dim filename As String
Dim lErrors As Long
Dim lWarnings As Long
Dim amountSaved As Double
Dim err As Long
Dim war As Long
Dim swdraw As SldWorks.DrawingDoc
Dim swsheet As SldWorks.Sheet
Dim swview As SldWorks.View
Dim name As String
Set swModel = swApp.ActiveDoc
amountSaved = 0
If swModel Is Nothing Then
MsgBox "Ei Olemassa Olevaa Tiedostoa", vbCritical
End
If swModel.GetType <> swDocDRAWING Then
MsgBox "Tämä Macro Toimii Vain Työkuva Näkymässä", vbCritical
End
Set swModelDocExt = swModel.Extension
Set swExportData = swApp.GetExportFileData(swExportPdfData)
filename = swModel.GetPathName
If filename = "" Then
'saves the SLDDRW file save as with standard name if not saved
Set swdraw = swmodel
Set swview = swdraw.GetFirstView
Debug.Print swview.name
Set swview = swview.GetNextView
Debug.Print swview.GetReferencedModelName
name = swview.GetReferencedModelName
name = Left(name, Len(name) - 7)
Debug.Print name
boolstatus = swmodel.Extension.SaveAs(name & ".slddrw", 0, 1, Nothing, err, war)
're saves SLDDRW when the SLDDRW already exist
'Save drawing
boolstatus = swExportData.SetSheets(swExportData_ExportAllSheets, 1)
boolstatus = swModelDocExt.SaveAs(filename, 0, 0, swExportData, lErrors, lWarnings)
If boolstatus Then
amountSaved = amountSaved + 1
Else
MsgBox "Työkuvan Tallennus Epäonnistunut, Error code:" & lErrors
'Save as PDF
filename = Strings.Left(filename, Len(filename) - 6) & "PDF"
If boolstatus Then
Else
MsgBox "PDF Tallennus Epäonnistunut, Error code:" & lErrors
'Save as DXF
filename = Strings.Left(filename, Len(filename) - 3) & "DXF"
If boolstatus Then
Else
MsgBox "DXF Tallennus Epäonnistunut, Error code:" & lErrors
MsgBox amountSaved & " tiedoston tallennus onnistunut"
Now I get At the very end " Compile error: Block If whitout End if
did you copy whole code or only part of it?
JUst part of it....
THANK YOu.
Modded so that it also says 3 files saved succesfully when saveing drawing as save as
