This content has been marked as final.
Show 3 replies
Re: Give BOM column a dropdown option with numbers or fillable form for pdf
Deepak Gupta Jun 12, 2018 6:51 AM (in response to Robert Voogt)I do not think you can do that within SW directly without using 3rd party tool. In case you are looking for a tool outside SW then try Able2Extract
Robert Voogt Jun 12, 2018 7:13 AM (in response to Deepak Gupta)I was affraid for that answer Will take a look.
Nick Cutler Oct 23, 2018 10:57 AM (in response to Robert Voogt)In addition to the above resource, you can also try using https://online-form-builder.pdffiller.com/ It allows you to fill out fields in the PDF, unlike Adobe which does not recognize fields. In any case, I managed to delete unnecessary fields manually and convert the document as necessary. I did not use Able2 Extract
