Why I map variable from data card to custom properties, the variable is added to Configuration specific instead of custom tab?
Hi Jake, sorry I meant your variable mapping in PDM. If you are using the CustomProperty block from your attributes, then it should go to the @ tab in the data card, and then on to the custom properties tab in SolidWorks. Make sure you have "Updates all configurations" turned on so that it will update both tabs.
Kind regards
Prasad
Hi Jake,
How are you adding the variable value?
Manually through updating the datacard? if so, ensure you are not excluding the @ configuration. Card Editor > Select the corresponding field, ensure "excluded configurations" area on the right side of the editor is clear.
Can you share a screen shot of your variable mapping?
Kind regards
Prasad
