AAAshok Anumula11/06/2018
I am trying to figure this out. Trying to use toolbox components, especially fastener.
When I insert a smart fastener I like to make a stack using the stack feature with-in the tool. What I can not figure out is how to use a ANSI metric standard screw with a DIN standard spring lock washer since, the Smart fastener tool only shows available washers for what ever bolt/screw standard you choose. (This would not be a problem if Solidworks toolbox had spring lock washers under ANSI metric)
Additional question: (When you copy a solidworks toolbox component across series how do you change their base units)
Any thoughts on how to do a stack using two different standards.
Thank you
Ashok.
