Hello! Mass migrated a ton of files from a non-vault setup to a new vault over the weekend and now wondering if its possible to bulk check them all in without having to manually do each job?
Thanks!
Thanks!
Hi Phil, yes, by multi-selecting all the folders in the root of the vault, you can right-click and select check-in.
Note: depending on how many files you have, the process may take a while. I recommend performing this task during off-peak hours.
Note also that if you have selected to not allow duplicate filenames, but you do have duplicate files to check in, those duplicates will fail to check in.
Yes, you can right-click on a folder, and select Check in.
Kind regards
Prasad
