Select Referene points one by one in 3D sketch
Question asked by Korbi Anis on Jun 10, 2018
Latest reply on Jun 13, 2018 by Manikandan Babu
Hello friends , I tried to write a macro that descritise a cylindrical face into points.I select the face , I created the sketch curve on this face and after I created a reference points on each sketch curve wich are already exist inside the 3D sketch . Can someone help me to select then the reference points one by one inside a sketch? thank you
This is the macro
Option Explicit
Dim swModelDocExt As SldWorks.ModelDocExtension
Dim swSketchManager As SldWorks.SketchManager
Dim boolstatus As Boolean
Public swPart As PartDoc
Public swFeatMgr As FeatureManager
Dim swSelData As Object
Dim vBodies             As Variant
Dim swBody As SldWorks.Body2
Dim swFace              As SldWorks.Face2
Dim sCurFaceName As String
Dim swEnt As SldWorks.Entity
Dim bRet                As Boolean
Dim lMark  As Long
Dim swSket As SldWorks.Sketch
Dim swFeat As SldWorks.Feature
Dim swMeasure As SldWorks.Measure
Dim status As Boolean
Dim errors As Long
Dim warnings As Long
Dim fileName As String
Dim swSketchArc As SketchArc
Dim swSketchPoint As SketchPoint
Dim radius As Double
Dim X1 As Double
Dim Y1 As Double
Dim Z1 As Double
Dim R1 As Double
Dim R2 As Double
Dim R3 As Double
Dim i As Integer
Dim swSeg As SldWorks.SketchSegment
Dim j As Integer
Dim somme(50) As Variant
Dim T(0) As Variant
Dim vRefPointFeatures As Variant
Dim swSketch As SldWorks.Sketch
Dim varc As Variant
Dim swPOINT As SldWorks.Sketch
Set swModel = swApp.ActiveDoc
Set swModelDocExt = swModel.Extension
Set swSketchManager = swModel.SketchManager
'=========================================================== SELECT FACE ==================================================================
Set swPart = swModel
Set swFeatMgr = swModel.FeatureManager
Set swSelData = swSelMgr.CreateSelectData
vBodies = swPart.GetBodies2(swAllBodies, True)
Set swBody = vBodies(0)
Set swFace = swBody.GetFirstFace
Do While Not swFace Is Nothing
sCurFaceName = swModel.GetEntityName(swFace)
If sCurFaceName Like "5" & "*" Then
Set swEnt = swFace
bRet = swEnt.Select4(True, swSelData)
swEnt.SelectByMark False, 1
lMark = lMark + 1
Set swFace = swFace.GetNextFace
Loop
swSketchManager.Insert3DSketch True
Set swSket = swModel.GetActiveSketch2
    Set swFeat = swSket
swFeat.Name = "SKET1"
' Convert edges of faces to sketch entities
boolstatus = swSketchManager.SketchUseEdge2(False)
' Clear the selections and close the sketch
swModel.ClearSelection2 True
'======================================================Measure diameter and center of the previous sketch 3D circle=====================================================================
boolstatus = swModelDocExt.SelectByID2("Arc4@SKET1", "EXTSKETCHSEGMENT", 0, 0, 0, False, 0, Nothing, 0)
Set swSketchArc = swSelMgr.GetSelectedObject6(1, -1)
Set swSketchPoint = swSketchArc.GetCenterPoint2
radius = swSketchArc.GetRadius
X1 = (swSketchPoint.X)
Y1 = (swSketchPoint.Y)
Z1 = (swSketchPoint.Z)
Debug.Print "X1 = " & (swSketchPoint.X) * 1000
Debug.Print "Y1 = " & (swSketchPoint.Y) * 1000
Debug.Print "Z1 = " & (swSketchPoint.Z) * 1000
Debug.Print "R1 = " & radius * 1000
'================================================================== INSERT NEW SKETCH ARC =====================================================================
    Set swFeat = swSket
swFeat.Name = "SKET2"
'==================================================================== CREATE CIRCLE  WITH INCREMENT MESURE DISTANCE BETWEEN R1 AND R2 =======================
    R1 = radius * 1000
For i = 0 To 4
   T(0) = 5
somme(0) = 0
somme(1) = 1 * T(0)
somme(2) = 2 * T(0)
somme(3) = 3 * T(0)
somme(4) = 4 * T(0)
somme(5) = 5 * T(0)
somme(6) = 6 * T(0)
somme(7) = 7 * T(0)
somme(8) = 8 * T(0)
somme(9) = 9 * T(0)
somme(10) = 10 * T(0)
somme(11) = 11 * T(0)
somme(12) = 12 * T(0)
somme(13) = 13 * T(0)
somme(14) = 14 * T(0)
somme(15) = 15 * T(0)
R2 = R1 - somme(i)
    ' Sketch a circle
If R2 > 0 Then
    Set swSeg = swSketchManager.CreateCircleByRadius(X1, Y1, Z1, R2 / 1000)
'==================================================== DESCRITISE SKETCH SEGMENT ==============================================================
    Next
    boolstatus = swModelDocExt.SelectByID2("SKET2", "SKETCH", 0, 0, 0, False, 0, Nothing, 0)
     boolstatus = swModelDocExt.SelectByID2("SKET1", "SKETCH", 0, 0, 0, True, 0, Nothing, 1)
  Set swFeat = swSelMgr.GetSelectedObject5(1)
Set swSketch = swFeat.GetSpecificFeature2
        Dim vSketchSegs As Variant
        Dim swSketchSeg As SketchSegment
        vSketchSegs = swSketch.GetSketchSegments
        swModel.ClearSelection2 (True)
        For i = 0 To UBound(vSketchSegs)
           Set swSketchSeg = vSketchSegs(i)
            If swSketchSeg.GetType = swSketchSegments_e.swSketchArc Then
                swSketchSeg.Select4 True, Nothing
vRefPointFeatures = swFeatMgr.InsertReferencePoint(2, 2, 0, 12)
        Next
Stop
'==================================== In this section I need to select the reference points ONE BY ONE !!!! ==============================
