I'm running problem using flow simulation Solidworks 2018 Sp2 and Sp3, when i run the turbine with rotating region it does not behave to the i want but when i run without rotating region the behavior of the water is exactly what i want, I never had a problem like this in SW 2014 and 2015.
ive attached my examples file of the above picture
I cannot attached the file i'm working due to rules but this is the picture of what im working
Another one is that i cannot find the option to select reference axis in the rotating setup environment so ive search in the google a picture of 2016 rotating set up environment and here is what ive found.
2016
for 2018 the reference axis dropdown is missing
