I have enabled 1:1 scale output. but solidworks does not give a uniform scale output for dwg file after conversion some of the entities remains unconverted to scale 1:1.
If anybody has suggestion than help me.
dwg file and screenshot of dwg file is also attached here for reference.
The easiest way to create a DXF of a sheet metal parts is SAVE AS from the model. This automatically creates a flat pattern DXF of the part. You can DXF non sheet metal parts also, but they should be in the view you want the DXF in for SAVE AS.
