Hi, I still can't find out how to replace appearance that's attached to multiple bodies, surfaces... etc
Assuming I want to replace circular pattern with sandblasted as on the picture, how can I do that? Do I need to add new appearance individually to each object or is there some trick to change appearance with another?
Hi Damir,
With the Appearance Selection tool on, you should be able to select the appearances that you with to change on the model (using Ctrl to multi select), then double click an appearance from the Library tab.
Note, this does not work when you double click on an appearance in the appearance tab.
The other method would be to use the Shift + LMB to copy and Shift + RMB to paste the appearances.
Hopefully that will do the trick!
Richard
