Macro not combining custom properties
Question asked by Fraser Port on Jun 7, 2018
Latest reply on Jun 8, 2018 by Christian Chu
I have been using the macro below (originally from Deepak Gupta to add the @drawing revison to PDFs which works perfectly. Now Im trying to combine it with a minor revison property (from the drawing called MINOR REVISION).
The result now only add the minor revision property to the file name.
How do I combine the two properties?
Thanks.
Set swModel = swApp.ActiveDoc
If swModel Is Nothing Then End
DateiMitPfad = swModel.GetPathName()
If DateiMitPfad = "" Then
    MsgBox ("Please Save First!")
    swModel.Save
Set swCustPrpMgr = swModel.Extension.CustomPropertyManager("")
swCustPrpMgr.Get3 "REVISION", False, "", Value
swCustPrpMgr.Get3 "MINOR REVISION", False, "", Value
sFilePath = Left(swModel.GetPathName, InStrRev(swModel.GetPathName, "\"))
FileName = Mid(swModel.GetPathName, InStrRev(swModel.GetPathName, "\") + 1)
FileName = Left(FileName, InStrRev(FileName, ".") - 1)
sFilePath = sFilePath
If Value = "" Then
FileName = sFilePath & FileName
Else
FileName = sFilePath & FileName & "_rev" & Value
swModel.SaveAs2 FileName + ".PDF", 0, True, False
