SW 2014, with current version of Adobe Illustrator. In a SW drawing, I can Insert Object > adobe acrobat > from file, (optionally link)
It appears in the drawing, I can position it and size the box it appears in.
However, this seems to only clip/unclip the PDF display, rather than changing the scale of the PDF.
But the scale/relative size of the PDF seems to change as I zoom in and out from the drawing.
This seems quite odd. How can I lock its scale/size?
Jay
I exported as DXF from Adobe Illustrator and used SW's Insert DWG/DXF.
The terminology and units between AI and SW still confuses me, but I was able to get them in and they look ok.
I suppose the picture import could have worked too, but I kept getting tiny images that still thought they were 5x2 inches.
I did not see the "sketch Picture" feature, but when I zoomed to the tiny pictures, they were not as clear as they should have been for the stated pixel resolution. Dragging them bigger did not seem to help either.
So DWG/DXF is the best solution so far.
