I've been given from a vendor a bracket drawn with autocad. It probably was created as a 3D part but I was given the 2D file as an ISO view, not ortho. So it seems I can not use the import techniques that are available when you open a dwg. The Solidworks 2D to 3D tool is designed to use the 2D ortho views. Are there any translational tricks for importing ISO views to make the 3D part?
Hello Steve,.. your DWG is only a "wireframe" (same as the IGES).. there are no solids/surfaces. and it imports into SW as wireframe.. so, you would need to create planes and sketches from the wireframe.
