Hi!
I created a balloon style to fit my needs, then saved it for future use. At creation I unchecked the "use document font" to specify something different than the document default. I thought that when loading the style in a blank drawing it would keep this setup but apparently not. The template document properties seems to drive the balloon style regardless. Can I do something about this or I will have to uncheck and adjust font each time I insert the new balloon? I must tell you that I do not have power over the template and will have to fix the issue on my end.
Thank you for your help.
Did you get it to work for you?
