I did not find answer for:
there is hole feature, holes positions are definened by 3D sketch, so holes axis are perpendicular to different faces.
How I can insert "hole derived pattern" the way my bolts alined parralel to holes.
Now axis of all bolts of pattern are parallel .
Hi Igor, I have tried doing this in the past with a sketch driven pattern (points in a 3D sketch). Unfortunately, the patterned holes would always follow the same plane as the seed hole. I think the next best method is to activate 3D sketch in hole wizard while doing placement. At least with this option, you can place holes on different planes, although it will definitely be a pain if you have many holes.
