visualize bottleneck
Question asked by Damir Galic on Jun 1, 2018
Latest reply on Jun 1, 2018 by Scott Ellery
I am trying to open a large visualize file (~400MB) and I keep getting some graphic card error (at the bottom).
Is this graphic card driver issue, graphic card memory issue or computer memory issue? RAM is used up to 13GB.
I get black screen for a second, then this crash.
Also:
polygon count 2,6 million
resolution 2200x1250
An error has occurred.
Error occurred at 14:07:28 on Friday, 01 June 2018.  Build version is 26.3.0.63.
SlimDX.Direct3D11.Direct3D11Exception = "DXGI_ERROR_DEVICE_REMOVED: Hardware device removed. (-2005270523)"
Stack Trace:
   at SlimDX.Result.Throw[T](Object dataKey, Object dataValue)
   at SlimDX.Result.Record[T](Int32 hr, Boolean failed, Object dataKey, Object dataValue)
   at SlimDX.Direct3D11.DeviceContext.MapSubresource(Texture2D resource, Int32 mipSlice, Int32 arraySlice, MapMode mode, MapFlags flags)
   at Bunkspeed.UDrive.Drawing.PassConstruction.PickingPassGenerator.ReadPickingObjectResultsClosestPixel(IDrawingPass drawingPass)
   at Bunkspeed.UDrive.ProjectDrawing.Manage.ProjectDrawingManager.PickNode(ISimpleCurrents currents, IAssetAccessor assetAccessor, IDrawControl drawControl, Point mousePosition, PickTarget pickTarget, Boolean allowClosestPicked, DrawingSettings drawingSettings, List`1 ignoreNodes, IProgressState progressState)
   at Bunkspeed.UDrive.ProjectDrawing.Manage.ProjectDrawingManager.PickNode(ISimpleCurrents currents, IAssetAccessor assetAccessor, IDrawControl drawControl, Point mousePosition, PickTarget pickTarget, Boolean allowClosestPicked, DrawingSettings drawingSettings, IProgressState progressState)
   at Bunkspeed.UDrive.Manipulate.Manage.DrawControlController.DrawControlMouseUp(MouseButtonEventArgs eventArgs)
   at Bunkspeed.UDrive.Manipulate.Manage.DrawControlController.WpfElementMouseUp(Object sender, MouseButtonEventArgs e)
   at System.Windows.RoutedEventArgs.InvokeHandler(Delegate handler, Object target)
   at System.Windows.RoutedEventHandlerInfo.InvokeHandler(Object target, RoutedEventArgs routedEventArgs)
   at System.Windows.EventRoute.InvokeHandlersImpl(Object source, RoutedEventArgs args, Boolean reRaised)
   at System.Windows.UIElement.RaiseEventImpl(DependencyObject sender, RoutedEventArgs args)
   at System.Windows.UIElement.RaiseTrustedEvent(RoutedEventArgs args)
   at System.Windows.Input.InputManager.ProcessStagingArea()
   at System.Windows.Input.InputManager.ProcessInput(InputEventArgs input)
   at System.Windows.Input.InputProviderSite.ReportInput(InputReport inputReport)
   at System.Windows.Interop.HwndMouseInputProvider.ReportInput(IntPtr hwnd, InputMode mode, Int32 timestamp, RawMouseActions actions, Int32 x, Int32 y, Int32 wheel)
   at System.Windows.Interop.HwndMouseInputProvider.FilterMessage(IntPtr hwnd, WindowMessage msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
   at System.Windows.Interop.HwndSource.InputFilterMessage(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
   at MS.Win32.HwndWrapper.WndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
   at MS.Win32.HwndSubclass.DispatcherCallbackOperation(Object o)
   at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs)
   at System.Windows.Threading.ExceptionWrapper.TryCatchWhen(Object source, Delegate callback, Object args, Int32 numArgs, Delegate catchHandler)
Direct3D Device Feature Level: Level_11_0
Microsoft Windows 7 Professional  Service Pack 1 - Pass
24 x Intel(R) Xeon(R) CPU           X5650  @ 2.67GHz - Pass
16367 MB RAM available - Pass
4096 MB NVIDIA Quadro M2000 - Pass
23.21.13.9158 GraphicsCard drivers - Pass
1 CUDA devices
11143 MB disk space free - Pass
9991 MB ram used by application
NeurayDeviceMode is Hybrid
