I have a resistor symbol which includes the attributes #TD_2 and #TD_3, which according to information from GoEngineer, for a resistor should link to the Power and the Resistance ratings coming from the Manufacturers Part number data.
It is a specialty part which I entered manually. I want to add the rating values to the manufacturers part number so it propagates to the symbol when I assign the part number. I am unclear on how to do this. How do I get to the #TD attributes from the Manufacturer parts manager?
Thanks in advance,
Lynne
You should be able to enter in it the manufacturer's database directly.
Make sure that you select the correct class (in this case, Resistors) or the appropriate Manufacturer Data fields will not show up.
The #TD_1 through 6 are different for each class and each class does not use all of them.
