Having a problem with sketch. after pulling up a plane, i create a centered rectangle. i then add dimensions to the rectangle, however, just recently, the rectangle, i'll add a side dimension, then when adding a top dimension, the triangle distorts. Help?
Rectangle? Triangle?
Q1. Why are you using SolidWorks?
Attach your *.sldprt file here and end all doubt.
