7 Replies Latest reply on Jun 1, 2018 10:51 AM by Ivana Kolin
    Macro to select the first component in the model tree
    Mike Childs
      I created an assembly and and have assembled a part that is used as a skeleton to attach the rest of the components. The skeleton part will always be the first component in the model tree and all of the other component placement dimensions are in that part. I need to be able to edit the skeleton part in my macro to modify the dimensions whenever there is a change to the assembly but the part name will vary every time the assembly is copied to a new folder within our PDM vault. Can anyone suggest a way I can select the skeleton component for editing regardless of what the component name is.
      Another forum post I came across suggested an example to traverse the assembly at https://forum.solidworks.com/external-link.jspa?url=http%3A%2F%2Fhelp.solidworks.com%2F2016%2Fenglish%2Fapi%2Fsldworksap… but I'm hoping there is a simpler way to find the first component.
      For clarification. The assembly will only have one config and the first assembled component, which is the skeleton part, will never be suppressed.
      Thanks for the help.
        • Re: Macro to select the first component in the model tree
          Artem Taturevych
          Try this
              Set swAssy = swApp.ActiveDoc
              Dim vComps As Variant
              vComps = swAssy.GetComponents(True)
              Set swComp = vComps(0)
              swComp.Select4 False, Nothing, False
              Mike Childs
              Thanks Artem.
              I had originally wrote my macro to edit a part in context in order to change dimensions and was trying to find the first assembled component as most of the dimensions are placed there. I would prefer to simply modify the component dimension at the assembly level and have been trying to find a way to do that but can't seem to get it to work. This is what I've come up with so far, bear in mind I have programmed in VB.NET before but I'm new to programming in VBA for SW:
              Dim swMdl As SldWorks.ModelDoc2
              Dim swComponents() As SldWorks.Component2
              Dim swDim As SldWorks.Dimension
              Dim rowCount As Integer
              Dim ComponentCount As Integer
              Dim atMarker As Integer
              Dim propName()
              Dim propValue()
              Set swMdl = swApp.ActiveDoc
              Set swAssy = swMdl
              swComponents() = swAssy .GetComponents(False)
                   For ComponentCount = 0 To swAssy .GetComponentCount(False) - 1
                        Set swComp = swComponents(ComponentCount)
                        Set swPart = swComp.GetModelDoc2
                        If Not swPart Is Nothing Then
                             Set swDim = swPart.Parameter(Right(propName(rowCount), Len(propName(rowCount)) - atMarker))
                             If Not swDim Is Nothing Then
                                  swDim.SystemValue = propValue(rowCount)
                   Next ComponentCount
              When debugging, swPart is always being set to Nothing and therefore is not triggering the lines to change the dimension. Is there an additional step I need to do?
                  Josh Brady
                  Your VBA syntax needs some spiffin' up.
                  GetComponents returns an array.  However, you don't know what size it is.  I'm pretty sure that in VBA the only variable that can receive an array of unknown size or type is a Variant.
                  I'm not even sure if you can use a Component2 array to receive the result from GetComponents if you resize it prior to.  Using a Variant is the way shown in the API help examples for VBA.
                      Mike Childs
                      Thanks Josh. The code I've shown does appear to populate the array, when debugging it adds 109 components to the array. I had originally used a ReDim command to set the array size but this seemed to work. It might be worthwhile to put it back in though.
                      I tried your suggestion to change the array to a Variant but I get a type mismatch error when running it.
                          Josh Brady
                          Dim swComponents As Variant
                          Dim swPart As SldWorks.ModelDoc2
                          Dim propName()
                          Dim propValue()
                          Sub poo()
                          Set swAssy = swMdl
                          swComponents = swAssy.GetComponents(False)
                               For ComponentCount = 0 To UBound(swComponents)
                                    Debug.Print swPart.GetPathName
                                         Set swDim = swPart.Parameter("D1@Sketch2")
                                              Debug.Print swDim.Value
                               Next ComponentCount
                          This works for me.  Note that swPart is declared as ModelDoc2 instead of PartDoc.  If the first component returned is a subassembly then you'll get a mismatch if it's PartDoc.
                      Ivana Kolin
                      GetComponents
                      The components returned by this method can be in any order. You should not rely on the order to indicate anything about children or parents. If the hierarchy and order are important, then use IModelDoc2::FirstFeature, IFeature::GetTypeName2, IFeature::GetSpecificFeature2, IComponent2::FirstFeature, and IFeature::GetNextFeature to retrieve your information.
