4 Replies Latest reply on May 31, 2018 6:13 AM by Krishna Kumar
    Macro Save SLDDRW with part name
    Roni Ampuja
      I have this kind of macro
         Dim swApp               As SldWorks.SldWorks
          Dim swModel             As SldWorks.ModelDoc2
          Dim swModelDocExt       As SldWorks.ModelDocExtension
          Dim swExportData        As SldWorks.ExportPdfData
          Dim boolstatus          As Boolean
          Dim filename            As String
          Dim lErrors             As Long
          Dim lWarnings           As Long
          Dim amountSaved         As Double
          Set swModel = swApp.ActiveDoc
          amountSaved = 0
          If swModel Is Nothing Then
              MsgBox "Ei Olemassa Olevaa Tiedostoa", vbCritical
              End
          If swModel.GetType <> swDocDRAWING Then
              MsgBox "Tämä Macro Toimii Vain Työkuva Näkymässä", vbCritical
              End
          Set swModelDocExt = swModel.Extension
          Set swExportData = swApp.GetExportFileData(swExportPdfData)
          filename = swModel.GetPathName
          If filename = "" Then
              MsgBox "Tallenna Tiedosto ensin ja kokeile uudestaan", vbCritical
              End
          'Save drawing
          boolstatus = swExportData.SetSheets(swExportData_ExportAllSheets, 1)
          boolstatus = swModelDocExt.SaveAs(filename, 0, 0, swExportData, lErrors, lWarnings)
          If boolstatus Then
              amountSaved = amountSaved + 1
          Else
      On the part
      If SLDDRW solidworks drawing isn't yet saved this MsgBox says this file not yet saved.
      I would like this to work so that if the drawing isn't saved It would save it with the same name as the part name. This is normally the preference.
      Ideally I would get MsgBox that would ask "drawing is not saved do you want to save this drawing with the name of part1.SLDDRW"
      Then just an option to hit ok or cancel and preferably the ok already highlighted Is this even possible.
      Rest of my macro is just to save PDF and DXF. But I just want this so I can save all 3 at the same time even though SLDDRW is never saved before.
      Thanks in advance
