This content has been marked as final.
Show 8 replies
Re: problem with animating cam and follower
J. Mather May 30, 2018 7:36 AM (in response to M. Ghanatian)-
M. Ghanatian May 30, 2018 8:39 AM (in response to J. Mather)-
Harold Black May 30, 2018 9:14 AM (in response to M. Ghanatian)Your setup works in Basic Motion
M. Ghanatian May 30, 2018 11:03 AM (in response to Harold Black)-
Harold Black May 30, 2018 11:07 AM (in response to M. Ghanatian)I was referring to the cam follower working in Basic Motion.
J. Mather May 30, 2018 9:34 AM (in response to M. Ghanatian)You will want to set up a Spring Force in Motion Analysis.
M. Ghanatian May 30, 2018 11:03 AM (in response to J. Mather)I am not doing motion analysis.Instead I'm doing animation
I have an spring with variable length that I have constrained it with the follower and the base
I actually did this tutorial: https://www.youtube.com/watch?v=qpXh6joZrLU&t=21s
Kemal Nurveren Dec 10, 2018 7:46 AM (in response to M. Ghanatian)I have same problem on my side. Try this work with Solidworks old versions such as 2016, 2017. You will see that it works. Maybe, SW 2018 has problem with cam mate or we are on wrong way. I tried many times this work with SW 2018. Result is same at every time. When I will push on the animation button, the some parts through each other like your screenshot.
