I tried to map an image around the edge of a box. First, I used the decal option, but the image was distorted all the time.
Second, i tried an apperance with the image as a color map. It was a really difficult to get this result:
- The Preview Mode is different from the accurate/fast mode.
- how can i avoid repeating the image?
- the Fit to part option shows a scale of e.g.123.9. If you want manually change the value 10 is the maximum.
As a result, the image is to small.....
The whole texture mapping is very intransparent and you need a lot of try and error and even more a lot of time
to get a result.
hmmm I'm surprised that decals didn't work , I would split both faces into different parts and use the multi part option.
or once splitting the surfaces create two identical decals and line them up on each surface to match up
