This content has been marked as final.
Show 2 replies
Re: Problems with shell simulation.
Micheal Johnson Selvaraj May 29, 2018 11:13 AM (in response to Anders Nielsen)Hi Anders,
I have gone through the model and the setup of the study, You have not given any contacts between the plate.
First, make a fillet bread which joins two plates, then give bonded contacts to plate and the fillet bread.
Then it will give you perfect answer.
Hope this helps.
Regards,
Micheal Johnson S
Anders Nielsen May 30, 2018 6:51 AM (in response to Anders Nielsen)Thank you for the quick answer.
I apologize for not being clear in the text above, but the main goal of the study is to use the Edge weld connector for the fillet-lap. I found the approach in the link but have not been able to recreate this study.
